can you guys help please , do you know of anything that would make the 4wd light on the dash come on and engage 4wd with the transfer in 2wd and the button on side of transfer stick out. when i pressed the 4wd button you could hear the relay clicking and the light would dim but it would stay in 4wd , i even tried putting into low ratio and then back again but 4wd light stayed on and also selecting all gears in auto box and the same . went into shop came back out and started car same at first reversed out of space and then 4wd light went out and worked normally shifting on the fly as well was fine, i am concearned that this is an indicator of problems looming
its a 1992 2.4 td auto
any advice welcome
jason
any advice welcome
jason
