just had my air con re gassed the guy put 450 grammes of gas in .does any one no if this is the right amount as with the aircon on its not that cold cheers
air conditioning
If he was adding to the original charge then the amount could be right.
However as your aircon still is not cold, and if you pardon the pun there are degrees of cold, why not just take it back and ask them to put it right.
Quite simply you have paid for a service which you have not received.
IIRC the last one I did took 750 or maybe 830 grammes.Eat.Sleep.Surf.Repeat.
Can you see bubbles in the sight glass?Originally posted by cupo View Postthanks for the replies the guy cleaned it out then put the gas in its been back twice now he is saying 450 grammes is the correct amount but it cant be as its shit
Is the suction line at the compressor sweating?
Not enough refrigerant,most probably.Eat.Sleep.Surf.Repeat.
The post 96 models left Japan with R134a gas being used.Previously they would have used R12.
I think.
There have been lots of studies carried out on the conversion of R12 systems to run on R134a.
Yes there may some issues with seals and yes some of the rubber hoses used may actually be permeable to R134a.
The conversion I did on my truck lasted at least 5 years before the underslung condenser was filled with Salisbury Plain and stopped working.
On my conversion I flushed the old mineral oil and used POE with R134a.
With regard to potential loss through hoses and seals I believe more will be lost through the compressor crank seal, through normal drying out of the seal when the compressor is not being used.Last edited by shokenore; 25 August 2013, 14:06.Eat.Sleep.Surf.Repeat.
He is probably looking at the data for a much later model ie one that is originally on R134aOriginally posted by cupo View Postwent back up there today he checked on the auto data site they used and it says on there 450 grammes he then said it cud be the pollen filter blocked so I looked there is no filter on thereEat.Sleep.Surf.Repeat.
