Tyre pressures.
  • Tyre pressures.
    Can anyone tell me what tyre pressure I should be running in my 275/75R17 tyres. I have extreame off road tyres on 17" steel rims.
    Currently I have 35psi but they look a bit flat and very noisy.
    inflate to 100 psi & float across the "stream"
    Or if you have extreme 17" off road tyres then I have no idea
      Some tyres will be noisy regadless of pressure, because of the tread design. Google "4PSI rule" for info on tyre pressures.
      Nev.
        Nev.
        That sounds like a good rule of thumb....to much heat is definitely bad.
        Anyone tried it on a standard Surf, by way of calibration?
          I followed Nev's advice a while back and with my average driving it figured out at 34 psi.
          However since then I have different tyres and the trucks primary use now includes more motorway work, so I should really start again.
          Eat.Sleep.Surf.Repeat.
            17" rims?? On a Surf????
              Yep. 275/75 R17.
              Got 2" lift springs on the rear.
              I touché a bit but a little trim stopped it.
