hi all been a while. i have a transmision oil fluid leak on the surf its gen 3. looks like the pipe has split its at the lowest point where it comes out of the sump and upwards, i take it to the dip stick . i,ve put my fingers around both the part thats comes out of the sump and above the leak upto the dipstick. and its dry. can this pipe / tube be replaced if so anyone know where from. and will i need a new gasket that fits around the pipe? thanks in advance.
transmision fluid leaking
Hi John, the ATF dipstick tube is in 2 parts, the top can be replaced easily but as your referring to the lower half connected to the Sump, a new sump will be needed ... unless ya fabricate sommat, solder the culprit or make a temporary repair with rubber hose n clips
F.Y.I.
3 gen sumps n 2nd gen sumps are different .. Robert
11+ Years of Surfs ..... n Faultless is my Yota !!Last edited by Diezel Weazel; 22 July 2013, 14:14.Buncefield Burner
bummer, saw the rubber grommit / gasket hoped you could just replace the pipe.Originally posted by Diezel Weazel View PostHi John, the ATF dipstick tube is in 2 parts, the top can be replaced easily but as your referring to the lower half connected to the Sump, a new sump will be needed ... unless ya fabricate sommat, solder the culprit or make a temporary repair with rubber hose n clips
F.Y.I.
11+ Years of Surfs ..... n Faultless is my Yota !!i x toyoyta surf 1 x toyota supra mk3 turbo auto
Last edited by mkiiisupraowner; 22 July 2013, 18:38.i x toyoyta surf 1 x toyota supra mk3 turbo auto
i,ve bought this
http://www.ebay.co.uk/itm/Loctite-Ch...1#ht_256wt_776
see if that does the trick. short term at leasti x toyoyta surf 1 x toyota supra mk3 turbo auto
