(okay okay, I know it's bad etiquette to post URGENT BUT i figured it's got more chance of catching someone's eye here than there - mucho apologies nevertheless).
Short version - Have fitted a 1.5" body lift, had loosened the 'pinch bolt' holding the steering clamp from the steering shaft and now, with the lift, I have no steering (as the shaft is now 1.5 inches above the clamp.
Why did I do this? well, because as far as I knew i'd removed the two correct nuts from the clamp - basically when I lifted the thing I expected to be able to split the clamp in half. This wasn't the case as I'd loosened the wrong two bolts (the _other two bolts are seized).
So. Question.
1. The steering shaft...any easy to obtain _longer_ steering shafts (and easy to swap).
2. is there any way of seperating the rubber from the two bolts I _have_ loosened (at the moment it seems wedged on tight). For reference, using the linked image, the two nuts I've removed are from the bolts _without_ washers. The ones _with_ washers are seized (and with the wheel turned 3/4 lock i can't get to the other even if they weren't).
http://www.4crawler.com/4x4/ForSale/...eering_mod.jpg
3. Any other ways of bodging a link from the shaft to the clamp?
The urgency comes from the fact that I was meant to be taking my missus camping in the thing. No good if I can't steer!
Winning suggestion gets a crate of beer (but only decent stuff, not shitty lager).
Much thanks for your patience and time.
Ant
So. Question.
Ant
