Hey guys
Just wondered on whether this is an expected issue and whether there has been worse!?
This is drivers side rear wing behind the cargo box - this is as bad as it gets this side, small hole, the rest of it is solid
This is passenger side, which seems to be much worse and has rusted through a strip along most of the panel. Still plenty of solid metal left though and more likely just causing more problems with water coming in
What are my options here? I have previously had an issue with my E30 BMW like this and I just cleaned it up, cut off any rotten metal, painted up with kurust, over painted with hammerite then covered with lead flashing tape, then covered that with tetroseal. I know I could get it welded up, but I'm guessing this is not structural?
Would like to get opinions on whether I should be particularly worried and what people thing are my best options here
Thanks
Matt
Thanks
Matt
