Bleeding Brakes In Halifax
  • Bleeding Brakes In Halifax
    Hi I've just fitted a new master cylinder and gone through 2l of brake fluid and I still have air! Is anyone able to assist in hAlifax, I will reward with many cups of tea!
    Air getting in around the bleed nipple threads....
    There was a similar thread on here a while ago.
    Air can get drawn in around the threads as you bleed the caliper,try some ptfe tape around the nipple thread.
      Do a search and read thru the threads on here, basically surf brakes are a bitch to bleed.
      there is a sequence to follow, and dont forget the LSV. If you cant fix it do what I did and take it somewhere who can pressure bleed it
      Good luck
      Alan
        I might be too late to lend a hand now as I've only just seen this thread, let me know if your still in a pickle & I might be able to bob over tomorrow night.
          Brakes
          Hi Si, thanks but brakes all bled & sorted now.
          Bought the clear pipe with the one way valve on so I could see the air coming out and catch the brake fluid. Its a cleaner more environmentally friendly way!
          Found out that when the new load sensing brake valve was fitted that the wrong pipe was connected to the wrong port.
            Glad your all sorted mate.
