Right, you're going to probably be fed up of hearing about this issue with the surf. However, my rear window worked beautifully on the key, dawdled a bit in warm weather but never the less still worked with a bit of patience, all until a friend of mine decided to pull on it to help it up....cheers pal.
Where my mither is regarding the situation is that I believe the window to have come off its runners??? As the motor sounds to be in good nick as it still makes all the noises when the key is in, and worked nicely beforehand is it likely to be damaged by all the pulling and dragging??
Either way I'm going to have to have the tailgate open, but rather than having to do it again, are there any kind of service/precautionary measures I can take to ensure smooth sailing in the future....I have another surf that I'm breaking that can be doner if necessary....I just don't fancy having to fix or replace something that isn't broken.
Thanks in advance guys, appreciate anybody that takes the time to help me out....other than that, I'm North Wales...why not drop by
