I suspect I'm going to have to address the suspension at some point soon. But I noticed a few threads where some of you guys have pointed out a saggy arse when viewing people's pics.
Mine?
It's reasonably comfy so I think the springs may be fine. It's on the sloped drive right now...so measuring it is pointless.
Dampers: Also, although not bad on a normal ride, it can get a bit bouncy. With the adjustable having a definite, but subtle, effect...it may be the case that the dampers are original Toyota ones.
On pull away it can, if too eager, feel like I'm on a bucking bronco. Whiplash is a possibility
Does that sound like Donald dampers?
The bounce test doesn't really do anything. Barely moves. But again...it's on my sloped drive so there may already be a lot of compression. Will check at the next flat park-up.
