Hi all
I am new to the world of serious 4x4 and have recently purchased a surf 4runner with KZN185 engine 3.lt TD Automatic with 108.000 miles on the clock.
Its is perfect in every way and it is the best form of transport I have purchased to date, much based on the reputation it carries as a hard nut.
Since purchasing, it started and ran as it should and pulls like a Trojan.
Last Sunday, I towed a Spitfire from Dover to London, with the aid of an A frame towing device.
Halfway home, I noticed the engine laboring to pull at a steady speed and I disengaged the over drive to give it some boost, on and off. but after a while, I noticed the temperature gauge to go right down to cold and little heat from the heater unit. I also noticed the gauge go up again for a short time and down again.
I am aware of the weakness of the these cars to be the head/gasket/some form of cooling problems, but there seems to be no signs associated with any of the above, as you would expect to see with an average old petrol engines, like oil and water mixture, power loss, starting problems water loss, and so on.
Has anybody else experienced this? could it be a simple solution? or am I just in for a large repair job?
Any help would be much appreciated.
Nader.
Nader.
myself.
