Hi all, just in process of changing diff oils.
Swapped rear mucky nasty stuff and topped up with 1.6ltr of fresh 80-90 gear oil. This makes the level about 5mm below filler.
Can anyone provide me with capacity for centre and front diffs?
Is the same oil used for centre diff or a different grade?
Is the front diff easy to get to when both bash plates are removed.
Finally got rear shocks changed, had to take it to garage, he wasn't a happy bunny.......2 hours to get the top nuts off. Got the Rancho's fitted now, ride still feels hard. I can push the Rancho shocks in quite easy by hand but extending them is very hard. Is this how it should work. The shocks that came off where very hard to compress but extended on their own.
Many thanks.
Many thanks.
