Just bought a 1990 surf desiel 2.4 got it home ran ok now wont start it has a clicking noise from the fuel pump is there a pump in side the pump to prime the fuel system ? glow plugs are live all the time please helpe me if you can not a good start to my surfing
Ln 130 will not start
Battery's not having enough power to power the Starter motor I would of thought.Originally posted by lloyd chalke View PostJust bought a 1990 surf desiel 2.4 got it home ran ok now wont start it has a clicking noise from the fuel pump is there a pump in side the pump to prime the fuel system ? glow plugs are live all the time please helpe me if you can not a good start to my surfing
Don't think there would be anything in a pump to make a clicking noise.
Battery connections tight ?
clicking
hi
i notice you say the glow plugs are live all the time
well if they are they should,nt be
they are on a relay and shut off soon after trying to start
if live at all time,s then this is prob cause
of batt going flat if this the case then all you will get is
starter clicking
check out yer plug relays and connectionsthe old git
thank you yes batterys were low and a fuel line leek air in fuel line new fuel line fully charge batterys now starts first click of the keyOriginally posted by inexorablej View PostBattery's not having enough power to power the Starter motor I would of thought.
thanks to all for your help bad starting due to air in fuel line new fuel line fitted re charge batterys now starts first click of the key even in this cold wether glow plugs working as they should !!!! dont miss my disco nowOriginally posted by lloyd chalke View PostJust bought a 1990 surf desiel 2.4 got it home ran ok now wont start it has a clicking noise from the fuel pump is there a pump in side the pump to prime the fuel system ? glow plugs are live all the time please helpe me if you can not a good start to my surfing
Glad to hear you got it sorted mate, bet you got a big grin now,Originally posted by lloyd chalke View Postthanks to all for your help bad starting due to air in fuel line new fuel line fitted re charge batterys now starts first click of the key even in this cold wether glow plugs working as they should !!!! dont miss my disco now
loads of good info and help on this site.
happy Surfing
Kind regards
J
