I recently had the ATF temp light come on when towing, and having just had the chance to get under the truck I know why.
The only transmission cooling I have is from an auxillary cooler which was installed before I had the truck, as the bottom of the rad has no inlet/outlets for this ( I assume a manual rad!). The other issue is that the trans cooler is almost lying on the bash plate therefore getting next to no air flow!!!!
I need to sort this so my question is, that if I use the stand alone cooler and just reposition it into the airflow, will I cause any problems to the box by over cooling - if that's possible?
I've done a search but opinions have varied in the past! I personally don't see how I can cause damage, but there are people on here with better knowledge of these boxes than I have.
Cheers, Nick
Cheers, Nick
