hi there this is my first time on this site i have spent the last two months working on this surf and getting no where i found a crashed hilux with a 2.8 3l engine in it i got it running in the truck before i took it out run well no smoke or bearing noise so the convershion begain i took my 2lte out of my surf
i stripped all the turbo efi set up sump etc bolted on to the 3l block plumbed up turbo done cambelt put efi diesel pump in put it all into my surf spent weeks checking wires found i had to replace coolant temp sensor and someplugs off resisters on the diesel pump will start and run off starter massive over fueling i think as very smokey .
i have had that motor running so the only thing im sure of is that should be fine i have never ever had so much trouble with a vehicle in my lift and ive worked on all sort lol
please please any help would be so appreciated heres i vid of it running at its worse
