Good evening all,
A quick question to the knowledgeable people out there.
I am changing the auto fluid soon and want to confirm that the filter is just inside the sump, and needs washing out with petrol etc and drying before being put back and sump re-sealed.
The other problem at the moment is that the selector will not lock in the park position. It can be pulled back at any time without pushing the gear change selector button. A while ago I was taking off rear prop and to release bolts at trans case end I pushed the red button to release the selector so I could rotate prop by hand to get to bolts and then lock back into park to undo them.
I was told that it could be the pawl inside the trans case and accessible whn sump is off. Or could it be a problem with levers and the little red button.
trans lever locks in drive to neutral, neutral to reverse and reverse to neutral.
It moves freely i all other positions, ie from drive down to 1. I was told it should lock in 2 and require button to get to 1.
Any views would be most appreciated before I change fluid and clean filter.
Regards
Andy
Regards
Andy
