Disastrous weekend working on the truck..
I've definitely started one of those jobs that I wished I hadn't!
It started off with a simple check over of everything, see if anything more serious had gone wrong to start the tyres catching the backs of the front wheel arch on lock..
As I had it all jacked up anyway I thought I might as well do the steering rack bushes, as they have been in need doing for ages, and I already had the spares, I popped the old ones out with such ease I thought Why not do the lower arm bushes too, while I'm under here ad things are apart..
Big mistake!
From looking at them last time (err this we before Christmas) I knew the camber adjustment tubes were seized solid, so after googling had bought a reciprocating saw and a load of quality "metal" cutting blades, new tubes, in theory everything to get the job done. On the plus point after some "spirited" off road driving recently, the passenger side had unsiezed, so no cutting required...
The driver side however is stuck fast, as I expected. The problem is cutting it out.. I have just spent many hours, and worn out 4 blades and just got 5mm through the first bush... Clearly the blades are no good, but I can't seem to find any better (they are the Devalt "demolition" ones, meant to be for cutting through metal pipe and girder, but the teeth look to big to me) they just sit on the surface and don't do much...
Can anyone either recommend the right blades for making the cut (or somewhere to look for some fine pitch metal blades I have tried EBay, B&Q and screwfix..) or give me any pointers?
At this rate I can only see using an angle grinder, and replacing the lower arm.., which I'd really rather not do... especially as I'm meant to be going away in the truck on Friday for the weekend!
To add insult to injury, the M3 picked up a puncture in B&Q car park, too!
Any help or suggestions please?
Big mistake!
