parked the surf up this morning, went back to it 20 minutes later to be greated with a puddle of antifreeze.
upon further investigation i found the leak to be coming from the rad around the connector for the ATF cooler.
it looks like a brazed nut in to the rad and the brazing has failed,
anyone else had a fault here?
a new rad should fix the fault i hope....
