judder
  • judder
    Hi all, my '93 3.0 hilux surf manual knz 130 has developed a judder when starting in f1rst gear. It only happens wher starting from 'dead stop'. if the wheels are moving even slightly it will not judder. It is fine starting from 'dead stop' in second gear, but this is not always possible i.e. when on a hill etc. I have noticed a slight judder (but not as bad) in reverse.
    It will judder in first and reverse from 'dead stop' in both two wheel or four wheel drive.
    I would be interested to know if anyone has experienced a similar problem, any thoughts or observations on the matter would be very welcome.
    Has the truck still using the original clutch and/or flywheel?
      Yes I believe so. It has 90.000Kms on the clock. The truck is like new and I believe the recorded kms. to be correct.
