I should probably supply subtitles for this.
I had a sticking piston in one of my calipers, I was changing the top and bottom ball joints and track rods so took the opportunity to get the brakes working as they should. I still had very effective braking as the piston would move out but not return fully which cause the pad to wear unevenly.
shopping list.
new piston
new caliper seal kit
new track rods
new discs
new pads
new brake pin kit
new balljoints, upper and lower.
So after stripping everything and breaking a few of the smaller bolts I drilled/ tapped and sorted out the offending rusty beggars, replaced with quality stainless fixings.
In the caliper I used an airline to get all the pistons moving out then replaced them and used a steel tube section to hold them in while I used the air method to blow out the stuck piston. It doesn't take much pressure and it can also be done with a grease gun but you would need to ensure the caliper internal spaces were cleaned out properly before re-fitting.
Vid of piston popping out. There was no need to screw the airline onto the caliper, just hold an air pistol against caliper.
Click video to play.
shopping list.
new piston
new track rods
new discs
new pads
new brake pin kit
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
