Hello folkes im new to surfs and know very little about them , i bought my 2.4 manual last year , it seemed a good motor then after couple of months the head cracked in 3 places between the ports as they all seem to do but at the time i thought it was just a head gasket and dumped the motor in the yard and used another until i had time to take a look , well that was october and last month " may " i thought i better take a look so i pulled the head off and found it was naffed . I bought a new one from ebay with cam installed ready to go for around £260 , plonked it on with a new gasket from main dealers £65 and the jobs a goodun , the only problem i had was an injector seal cracked when putting them back so it was drawing air and giving a huge knock on the number 4 cylinder which was very worrying after installing a new head and timing a surf for the first time only to hear this trajic metalic banging sound but its all sorted now with a new set of top and bottom seals from ebay £7.50. Any way im looking to put some bigger wheels under it and have been looking at ways of lifting it , i have ordered a 2" bodylift kit and a pair of +2" uprated rear springs which should sort the back end but for the front end i was looking at balljoint spacers and diff spacers etc , ive seen a set on ebay but they look a bit cheap and nasty to be honest and for £65 ! My plan is to make them myself cheaply using 1/2" ally plate with 1 1/2" of polyethelene board behind , hopefully it will work fine but if anyone thinks its a stupid idea let me know why please so i can rethink my plan before i start lol. The main question im asking is if a put a 2" spacer above the top ball joint does the sway bar and diff have to be dropped by the same amount , also does anyone have a link for step by step instructions on cranking the torsion bars preferebly with pics , many thanks The Gov
