Hello folks, New guy here. I have a beater 1992 Surf with the 2.4 TD that I use to travel around on my base. Unfortunately I do not have the normal resources available to me that you guys do. I have 3 issues that I am working on. One should be a fairly simple fix once I can get the parts in my hand.
1) The A/C is inop (compressor is locked up, cut high pressure hose)
2) Check engine light is on. I have a code 4 and also an 11.
The code 4 ,I found a green wire going to the water temp sensor is cut by the timing belt cover. I am not sure where this wire is supposed to go? I did notice a triangular shaped connector just below the A/C compressor is open and there is nothing that is connected to it?
3) The heater/ A/C fan is inop. I did notice 2 relays and 2 blade type fuses but I found what appears to be a slot where a maxi fuse goes but there is no fuse? If there is a fuse that belongs there can someone tell me what fuse belongs there? Thanks for the help.
