I was getting a bad vibration at speed and after a good look underneath this morning found the Universal Joint at the gearbox end of the rear driveshaft is very worn. I've got the driveshaft off and ordered the new UJ from Milners but I can't get the old one out of the holes in the driveshaft. I've removed the c clips and got the biggest G clamp I can find on it but can't force it out, do I just need more force (bigger clamp?) or is there a trick I'm missing. The Haynes manual says it should just push out.
Thanks anyone that can help
Darren
Darren
