After a trip round the plains I looked at the engine and as usual it was coated in mud. There were only 3 puddles all day.
So, have any of you made something to stop the ridiculous amount of slop coating everything?
I presume it would have to be fairly carefully made too as cooling is fairly important.
Does having half the rubber flaps missing in the front wheel arches add to the problem?
Would it also be possible to at least make an alternator guard? My idea was for a small panel bent round so it shields the under side then something above it on the bonnet to stop any mud from the top from getting to a position to drop on to it.
