Steering wander
  • Steering wander
    Hello good Surfers
    I recently had my track rod ends replaced on my KZN130 and it really tightened the handling up but then came the mot and we had to change an inner cv boot, put new pads on and change the tyres from front to back, doing the cv boot obviously required the one side of drive etc to be dismantled and the back (now front) tyres are older consequently the truck now wanders as it was before the track rod ends were done!!(50mph and above) I've noticed there is play in the steering column (the section in the engine bay, about an eighth / quater of a turn) I've checked for play in all the other moving parts of the steering and it all seems tight (done with all wheels on the ground and engine off), any ideas why she is wandering again????? Please!!!
    start off by swapping the fronts and rears again.
    well, that was a bad idea!
      was it re-tracked after the cv boot change?
      If it wasn't, it should have been.
      I managed to track mine with a six meter straight edge lol, and a lot of patience.
      Put the back tyres to the front and likewise inverse, as stated above, and drives like a dream ever since.
      Everything happens for a reason, and only one way....
      The way it does!
