I'm having a bit of trouble selecting h4h2 at the minute on the lever. I took the transfer lever off to have a look, as it needs straightening up anyway, and it looks like this (see below) with H4L showing on the dash - which seems wrong as I seem to recall the two cutouts lining up before in H4L to make a square...
I can't work out if it's the left rod that should be up a position or the right rod that should be down one, or even if I'm wrong and they shouldn't line up. The right rod won't move down at the minute though, and the left won't move up... so I'm stuck in 4wd.
Any help would be enormously appreciated as my car's off the road until I can get it sorted and we were supposed to be going away Easter weekend!
