I noticed a squeaking sound coming from my truck when reversing the other day. I found that it seems to be coming from the UJ that links into the rear diff.
I got under and had a look, there was no excessive play on the UJ or propshaft or anything like that, so i pumped some grease in there but it didn't cure it. There's no noise whatsoever when driving forward, only when reversing. It only happens when the prop moves, not when the truck's pushed backwards in neutral.
I'd replace the UJ, but it's hard to tell if that's exactly where the sound's coming from, as i can't get under the truck and reverse it at the same time... Just wondered if anyone had any ideas?
Cheers.
Cheers.
