Evening all, my trucks osf suspension has started squeaking over bumps . Now I've had my mate bounce up and down on the suspension while I had I hunt around for the noise . It seems to be coming from the upper suspension arm inner bushes .I tried to be certain by spraying them with penatrating oil to stop the squeak but it won't stop . Which make me think maybe it has something to do with the tortion bars were they bolt to the top arms . Has anybody had experience of this before? thanks for any advice in advance
squeak !!
Thanks for the idea but I have already tried that . I'm sure its coming from the upper suspension arms but to be defo sure I'm going to remove the the arb bushes and grease them and refit them. And I have a new set of front shocks to put on but I don't think that will solve itAlways up to my neck in it
Originally posted by ezza24 View PostThanks for the idea but I have already tried that . I'm sure its coming from the upper suspension arms but to be defo sure I'm going to remove the the arb bushes and grease them and refit them. And I have a new set of front shocks to put on but I don't think that will solve it
Ok I take back my last post, after having another look tonight the squeak seems to be coming from the upper ball joint , I always keep the joints well greased . Now in the few miles I drive to work and back each day I don't think I ever put the truck on full lock in either direction, and by just turning the steering lock to lock several times tonight the noise has almost all totally goneguna pump a bit of extra grease through it tomorrow and I hope that's it thank for the advice peeps
