Hi all
Had a creep under the car today and noticed a slight leak from the transfer box rear output shaft seal. Are the easy to do it yourself, or best given to a garage.
Also noticed what looks like the gearbox / transfer box support bracket, which was two rubber blocks in it. Noticed that one of the blocks is on the move and could ideally do with replacing.
Seen some for sale at roughtrax or milner offroad, but ae they easy enough to fit.
What is the best position to support and lift the box whilst removing the old bracket. Might tackle that soon if the weather does improve a little. Not tthe best laid on a cold wet drive doing these things.
Regards
Andy
Regards
Andy
