I changed the radiator today, easy job(many thanks to roughtrax) but after putting all the pipes back on I noticed a large amount of oil on both the engine guard and all over the bottom right side of the engine and steering. It's coming from half way up below the power steering reservoir and I don't think it's engine oil. I am guessing it's power steering fluid but not sure. Has anyone else came across this problem and know where its coming from?
Oil leak maybe?
If the oil was'nt there before you changed the rad, it'll be tranny fluidOriginally posted by Sparkey View PostI changed the radiator today, easy job(many thanks to roughtrax) but after putting all the pipes back on I noticed a large amount of oil on both the engine guard and all over the bottom right side of the engine and steering. It's coming from half way up below the power steering reservoir and I don't think it's engine oil. I am guessing it's power steering fluid but not sure. Has anyone else came across this problem and know where its coming from?
from the two small pipes running to either side of the bottom radiator
tank.Still on a mission.
