hi guys need some help. when i put my kzn185 into park sometimes the key wouldnt come out but if i moved the auto stick back to L the upto P again it would have came out but now it will not come out at all. anyone know my problem and how to fix it????? thanks
key wont come out
I had a similar issue the other day. Left the car parked for 10 days, went to jump in it and used the truck. Stopped and the key wouldn't come out yet it was in P. The way I managed to get the key out was to switch the ignition on and pretend to start the car without disabling the immobiliser and then quickly turn it to the off position. Only did this twice and not done it since so I guess it was a sticky switch/sensor or something due to not being used for a while.
Probably not related to your issue, thought I would comment though
Nope you have a leak......it's associated with the pedal on the right, when pressed the fuel leaks through the cylinder and down the exhaust!!!Originally posted by Wolfracer View PostI've got a side light out and can't get the fuel to stay in my tank, are these related?
Oh cr@p, better stick some radweld in the fuel tank in the morning then!Originally posted by tonupteabag View PostNope you have a leak......it's associated with the pedal on the right, when pressed the fuel leaks through the cylinder and down the exhaust!!!
www.johnthebuilder.info
Mine used to do that, if u push the gear select a little more into park position it releases the key. U should hear it click too when u slide it into park, there is a small switch under the plastic which needs to be pushed all the way in by the gear selector.ALL THE GEAR!............no idea!
