Has anyone on here modified their braking system and what were the results?
I have seen many posts regarding different pads and braided lines but none discussing alterations to the brake booster or master cylinder to gain more mechanical advantage. I found this article and it got me thinking about ways to improve the Gen2 braking and what parts from other vehicles could be used achieve it.
http://home.4x4wire.com/erik/4runner/brakes/
Having started my 1UZ conversion and considering a supercharger system brakes are one thing I dont want to find lacking!
I realise that the bigger the tyre the more leverage on the braking system therefore effectively reducing the strength of the brakes and increasing the effort to use them. I run 33's at the moment and as predominantly a road car wont go any bigger.
I am considering a slightly smaller 15/16" master cylinder from a corolla or similar to regain some advantage and offset the tyre effect. This coupled with some EBC pads with more bite and braided lines should go some way to assist.
Modern systems use brake assist which I assume increases the vacuum at the diaphragm to increase braking power and reduce effort at the pedal I need to research a little more but wonder if a system from a more modern vehicle ie its vacuum and diaphragm system would retrofit. Another option would be to ry to increase the vaccum at the existing diaphragm to increase the assist.
Thoughts and experiences please
