hi tried 4wheel drive while stuck in a fieid not workin light is comin on nothing happens checked all wires and vac pipes all are connected anyone got any ideas what to check its not got free wheeling hubs its a 94 3litre limited cheers
4wheel drive not workin
Pull the hose off and put your finger over the barb, you should feel the vacuum switching from one to other.
Bare in mind if they arn't switching, it could still be something on the t/case not telling the ECU to switch the solenoids, so better to check the plugs with a multimeter to be sure.4x4toys.co.uk - Keeping you on and off the road...
