I have seached hi and low through posts but i have a diffrent fault than the rest. Its a 2.4 ln130 Manual
The 4wd light works, front diff (add) system works fine and light on dash says 4wd is on, But i get no drive to the front prop!
If i jack up the rear and spin the front prop by hand (2wd mode selected)
i get a little movement on the rear prop and wheels as i think i should but not locked in .
With 4wd selected light is on and front adds kicks in fine but still if i spin the rear wheels no power to front prop like its not locking down.
So my questions are ? The transfer box 4wd selector moter the locks in the front prop in, can i remove it without the t/box oil coming out and push it in manual to see if it is the moter or the t/box
Would the light not flash if it wasnt locked in or something?
Ps I also get no light saying 4wd in 4L only if i push the button
Anyone got a wiring pin out for the moter 3pin plug and a 2pin i think?
Speedo also dosnt work but tested sender and i think its the dials this wouldnt affect the 4wd would it?
Thanks in advance for reading all this
