hi all, i recently got myself a 2.4td k reg hilux surf and have a few queries...
im planning on carrying out a 2" suspension lift very soon using front and rear uprated shocks and 2" lift rear springs, will i need to extend any brake lines etc when i do this or would that just be if were doing a body lift?
next thing is im well aware of these particular engines having an over heating problem, mine seems to be fine at the moment but is there anything i can do to prevent it happening in the first place? such as removing the viscus and fitting an electric fan etc?
ive only just got it and im not to familliar with these so is there any other things i should be aware of? i have read the faq section so anything other than whats in there
many thanks in advance
