Ive beem searching the net for the info bit its quite sketchy
How did you turn your aircon pump into a air pump?
Did you change the pump to a more compatable unit or is the stock pump suitable?
Im thinking of using a range rover air shock 2.5 gallon tank and hiding it out the way
Can you shed a bit more light onto the subject for me?
Luke
Ps. The motor in Question is my 95 manual ssrg
Luke
