hi all, im new to the hilux world, i just purchased myself a k reg hilux surf ssrx 2.4 td extremly cheap for some winter fun, it was cheap because i was told it needs some tlc...as it goes it doesnt seem to need that much, im fairly mechanically minded so working on it wont be a problem and i will try to understand as best i can as to what im being told.
basically my main problem at the moment is when slowing down from around 60 mph i get a slight vibration/judder, its fine when pulling up through its just when i back off the throttle then at around 40 it stops
could this be a prop out of balance/bent slightly? if so is there anyway of checking this?
if you need any more info please ask
thank you in advance
