 hi all ive got a problem whith my toyota 2.4 man tdi first thing was when i put the truck in first gear it would crunch it was also getting really hard to change gear ... i was told it was a clutch problem so i went and changed the clutch new clutch fitted and still no change will not go in to gear even when clutch is pressed if engine is off it will go in to gear then... But it wants to move off when starting engine and clutch pressed so i changed clutch slave cyl all bleeded up still no change so i tryed to extend the bar on cyl to push the foulk in further still no change can any one please help me
 hi all ive got a problem whith my toyota 2.4 man tdi first thing was when i put the truck in first gear it would crunch it was also getting really hard to change gear ... i was told it was a clutch problem so i went and changed the clutch new clutch fitted and still no change will not go in to gear even when clutch is pressed if engine is off it will go in to gear then... But it wants to move off when starting engine and clutch pressed so i changed clutch slave cyl all bleeded up still no change so i tryed to extend the bar on cyl to push the foulk in further still no change can any one please help me  thanks
 thanks
 Manuall gear box problem
