think the rattle is found - bush help please
  • #31
    Originally posted by lawsy
    Air can rad removed and pipes (didnt work anyway) belt removed on aircon pump - is it ok to leave like this for a bit or do i need to strip out more?
    When I stripped mine out, I removed the lot. But it's OK to leave it the way you have it now.
    • #32
      Cheers..
      I'll start stripping it back over the next few days etc, just wanna get the wishbones sorted first and back down on 4 wheels ASAP
      But whilst I'm waiting I may as well trace it all back and remove
      Looking at the pipe, there are 2 that flow into the passanger side of the cab, I'm assuming a flow and return to the AC unit, did you strip all these out too?
      and sorry for all the questions..
      just to ease my own curiosity whilst i await a call back
      the poly bushes come with an inner sleeve, an outer sleeve and the bush
      the outer sleeve has a 'top hat' effect to it, is there a reason for this?
      Does it go in one particular way?
      I'm sure it'll become clear once they come out/go in tho..
      also, pressed on the end of the old bushes are some round discs, kind of like big washers, are these needed to be kept and re-used with the polybushes?
      • #33
        I stripped the lot out, the only things left were the bits inside the truck. I was bored...
