Originally posted by lawsy
think the rattle is found - bush help please
Cheers..Originally posted by Albannach View PostWhen I stripped mine out, I removed the lot. But it's OK to leave it the way you have it now.
I'll start stripping it back over the next few days etc, just wanna get the wishbones sorted first and back down on 4 wheels ASAP
But whilst I'm waiting I may as well trace it all back and remove
Looking at the pipe, there are 2 that flow into the passanger side of the cab, I'm assuming a flow and return to the AC unit, did you strip all these out too?
and sorry for all the questions..
just to ease my own curiosity whilst i await a call back
the poly bushes come with an inner sleeve, an outer sleeve and the bush
the outer sleeve has a 'top hat' effect to it, is there a reason for this?
Does it go in one particular way?
I'm sure it'll become clear once they come out/go in tho..
also, pressed on the end of the old bushes are some round discs, kind of like big washers, are these needed to be kept and re-used with the polybushes?
