Originally posted by LCR225
View Post
Leaky rear
Nah, I have a press and made the special tool from the end of an old axle housing to press all the collars, ABS ring and bearing off without damaging them.Originally posted by BUSHWHACKER View PostWhat do you do about the ABS ring, cut it off and replace with new?
You don't side to side play on the rear bearing because of the halfshaft, you need to take the drum off and hold the flange and pull it in/out to check for wear.Originally posted by LCR225 View PostI guess if it was that I would notice some play if I grabbed the wheel and rocked it... Or would I? I have tried that and its solid... So I hope it's not that.
I plan to get working on this tonight... So time will tell!
Panic over... Hopefully.
Checked the truck out this afternoon and checked the breather before taking things apart and it was locked shut. So I decided to take the top off and route a pipe to the inside of the truck to avoid the problem again.
Took the drums off and the shoes were all clear of oil.
so I cleaned all the small parts of oil up and will keep an eye on it over the next few days. I also topped the diff up and it didn't take much at all so I think the breather was the cause. The oil started to appear the other day when it was warm and after a drive down the motorway so hopefully all is good in the rear department now.
I noticed the other day there was oil running down he OSR wheel on the inside edge of it. This weekend I took the wheel off to take a look and this is what I found:
IMG_0173 by ukactionsports, on Flickr
IMG_0174 by ukactionsports, on Flickr
IMG_0176 by ukactionsports, on Flickr
Now I wasn't sure what the grey gunk is... Could it be the wheel bearing grease as I noticed there's a lot of in/out movement. Video of it: http://youtu.be/xIN6JDYAxeQ
You need one of these....
http://www.roughtrax4x4.com/?doc=16&cid=177&vid=232
And a set of these....
http://www.roughtrax4x4.com/?doc=16&cid=171&vid=337
Agree with bushwacker thats the parts needed to stop leak in wheel cylinder and renew contaminated brake shoesOriginally posted by BUSHWHACKER View PostYou need one of these....
{IF IT AINT BROKE MODIFY IT}
thanks! I have the seal and some shoes sat in the garage waiting to be used so I'll crack on this weekend. How long would it take to do? 1.5hrs?
Whats the verdict on the video? There seems to be a lot of movement in it, more then I noticed before.
