thanks for advice on my bad brakes following caliper change.
Bled all brakes again tonight, using gravity bleed technique and bleed kit,
I couldnt manage to bleed the load sensing valve, the bleed nipple was too corroded and I didnt want to risk snapping it.
brakes are better than they were last night, same as before the new calipers. I still think they should be stronger.
That long arm on the load sensing valve was seized at the end where it joins valve, I relesaed that. But it is still seized at the wheel-thing (No.2 shackle!) at other end, the part mounted to a metal bar (no.1 shackle) moves, but not the near-right no.2 shackle.
andy
andy
