Hmmm,
Thought i would flush the auto trans box and refill with fresh dextron 2.
No big deal i thought, two buckets and one filled up with fresh to be sucked in by the tranny pump the other for the waste!
Except what ever i do It wont suck up the fresh fluid!!
I hope its not the sign of a knackered pump, It dumped about 5 liters out of the sump easily enough,which i have now replaced with fresh through the filler tube!
I do have a transmission cooler fitted and i was trying to suck through the cooler to fill. Surely that cant make a difference the pump seems to work ok when the system is sealed as normal! Or does someone know different?
Any suggestions welcome as I may end up going to a transmission specialist to be relieved of many, many pounds!
