Hello, I'm currently changing all the fluids in my surf and I've got a little stuck on the front diff.
I've found the drain plug easy enough and I'm assuming this bolt in the centre of the picture is for refilling but I would like to check for definate before removing it.
the picture was taken from the front of the surf looking backwards
Also whilst changing the fuel filter I noticed this pipe with a screw in the end. It appears to be attached to a one way valve or filter and its other end connects to what looks like the throttle body although I could be wrong.
Does anyone have any ideas as to what it's for?
Thanks very much. There was something else important I had to ask but my brain has deserted me, if I remember I'll edit the post.
