What a great site and hello all from a newbie
Need some advise please. I have read through the threads on Idling issues but hope to get some feedback on mine;
My "well looked after" surf 1995 3.0 TD has developed the following:
1. Cold start Idles at 750rpm constant
2. During first journey at Idle speed drops to 600rpm with signs of vibration
3. Turn engine off and restart the Idle speed goes back to 750rpm.
I know some of your will say this could be normal but this only started showing the difference over the last 2 weeks with the vibrations. I read about sensor readings / faults from TPS / Water and the IAC and wonder if (no mechanic) if the IAC valve is picking up carbon build up on the throttle valve or could this be more simple in diagnosic. Anyone had the same problems and could advise me please on the first steps to investigate. Problem did raise itself one year ago with reduced rpm and my local garage moved the throttle screw by 1 revolution to raise the idle (I know this was not the answer to explain the drop in rpm then - and so did he).
Any guidance most appreciated. Andy
