A lady friend of mine has a nice '92 HiLux import. Her problem, for some time, has been that she is unable to use the rear as the window won't work.
You can hear the motor running...in both directions and taking off the interior trim you can feel it turning so I guess the wiring is ok. The switch in the front works the same.
As we can't open the window, I am having to work from inside. I guess a choice of faults may exist, 1. Thje motor is not turning it's worm gear to move the toothed quadrant or 2. The teeth of the quadrant may be stripped at the point where the motor sits. I think the next thing to do is to remove the motor, plug it in and see if it's moving it's little gear against load and at the same time check the quadrant teeth and lube all the channels and various moving parts. I assume that when the motor is removed then the quadrant will be free to turn and move the glass.
I noticed, when swinging the spare wheel back, that there is a plastic panel in the tailgate where the number plate would be on other models. Is this removable and if so, would it make the job easier ? It's not comfortable trying to get a hand behind the motor and regulator to undo things. Especially at my age ! I've read all the forum posts on the subject with interest and I now have a good vision of what happens in there.
I do have 30odd years experience with vehicle mechanics but mot with this particular problem..The bulk of my work involved diagnosis and breakdowns
Any hnts and tips for motor removal woulf be appreciated.
Ed
Ed
