hi i have a 3.0td surf and was running it on fully cleaned and filtered bio diesel for approx six months, then whilst driving it lost power and engine check light came on, it still starts drives fine but wont go over 3000 rpm or 40 mph. There is no smoke of any colour when driving, but when throtle is held for about 10 sec at 1500-2000 in park it runs lumpy and white smoke comes out of exhaust, but not when driving. Here is a list of things ive tried to solve this. The day the fault started it ran out of fuel but topped up and it started fine and i drove about 20 miles before fault came on.
Drained fuel, blown lines back to tank, new fuel filter, cleaned little filter on pump (allthough it wasnt dirty at all) and filled with fresh white derv.
tried running from a fuel can under bonnet but still ran the same
done the paper clip diagnostic test and i get as follows 1 1111 1 1111 1 1111 and so on with over drive light flashing so i guess this is fault code 14? is this correct?
disconnected batteries overnight but still the same fault
it runs the same on bio as it does on white derv with no difference
tried running without hand primer but still the same
new fuel pipes from steel ones up to primer and pump and primer works fine
cracked all injectors whilst ticking over and engine revs drop on every one when opened.
If someone could help or have any suggestions then i would be very gratefull as im new to surf ownership and its a great motor but this isnt helping at all
