Hi fellow surfers.
I have recently changed my clutch slave cylinder as it was leaking fluid and the clutch pedal was sticking to the floor and not releasing making gear change impossible. After changing it and bleeding the clutch I put it all back together and thought everything would be fine but it is not it is still the same only getting worse and it is now falling out of 1st gear every so often causing the truck to abruptly stop with a clunk. I thought I might have left some air in the pipe so bled it again but their was no trapped air. I did swap one of the break lines over without bleeding it would that be a reason for concern.
Im automatically thinking the clutch or even the gear box is on its way out because it sometimes falls out of 1st when going slow mostly just pulling off. the clutch pedal also seems to be at its worst when you are pulling off or reversing when you have to ease off the pedal slowly.
I hope some one has a good idea what is wrong.
Thanks
Thanks
