Hi all,
i could really use some sound advice on my 2nd gen surf. its 1995 3.0 td. It runs fine running around the town but on the motorway if i push it to 70mph or 75mph the temp starts to rise to just below the red. If i slow down to 55mph it cools to halfway. It has done approx. 87000 miles, the head was replaced along with the water pump and radiator at approx. 65000 miles by the previous owner, the receipts are in with the history. Is it possible the head is cracked again ?? Or could it be something simpler?
There is no sign of oil in the water or water in the oil and im not losing any water from the cooling system, the levels are fine, oil and water. There is no smoke bellowing out, none at all. I can leave the engine running and the vehicle standing and there is no overheating, fans seem to be ok. Any advice would be much appreciated.
