Hi all,
I’m having a few problems fitting the 2 inch spring lift kit from Roughtrax (springs and dampers). I have a 3rd gen which has, so far been bullet proof. Serviced last year by Tony, run on 50% veg during the summer, and passed its mot with flying colours a few weeks ago. I love working on it as it’s just so easy to get to everything.
That is until I started on the suspension lift.
The rear dampers top nuts were both buggers to get undone, and in the end I resorted to an angle grinder and sabre saw and cut them off. But the fronts are proving just as tricky, but for other reasons.
I can’t seem to be able to wind the spring compressor up enough to pull the spring down so the top of the current damper clears the top hole. Its close, but as I can only get one compressor on, the spring is pulled over quite a lot.
My fear is that if I continue, and get this current spring out, I’ll not be able to get the new longer / tougher one back in.
One option I can see would be to undo the bottom steering ball joint from the lower wishbone, and gently lower this down using the trolley jack. In theory it looks like this would then allow me enough movement to easily remove the damper and spring in one go, and replace it with the new kit. Then (in theory) I can raise the lower wishbone back up into place, slot the top damper bolt through the hole, and re attach the steering ball joint.
I have looked at this a few times now, and that seems the best option to me.
Can anyone tell me if this would work, or if there is an easier way that I haven’t seen.
Failing this, it’s time to call Tony, and book it in. As I also have the longer break hoses to fit, this is looking like a nice option.
Any help appreciated
Nick
Nick
