Hi, I am having some brake issues on my 2.4 LN130. Started off with dash brake light appearing on start up. After a few seconds it would disappear. Checked fluid level which was a bit low so topped up, problem disappeared for month or so, then returned. Fluid level was fine this time, so guessed it must be pads/shoes. I duly fitted new Pads and Shoes all round, drums and discs looked ok. Gleefully jumped aboard the truck and found no change!
Today I have bleed the brake system and slight change! (Although brakes couldn't stop a draft!)
What seems to be happening now is dash brake light only comes on when brake pedal is pressed down, light stays on until engine is reved. I have looked round master cylinder and servo and cannot see any fluid loss, it's kind of like a loss of pressure somewhere? When pedal is pressed it hits a point and then slowly sinks, but does not pump up to firm.
Anyone had the same or got any ideas??
